Author Topic: exhaust  (Read 1970 times)
jrobie79
exhaust
« on: October 01, 2007, 01:06:09 PM »
i foosed up my exhaust real bad when i tried to put on a dynomax muffler, now the thing is all bent up and doesnt sit right and vibrates all over the place, where can i get another exhaust setup, i got a welder at home so i could do that, should i see if a shop will bend me some pipe and i could weld it up myself.
oldtimer
exhaust
« Reply #1 on: October 01, 2007, 09:53:23 PM »
you can do the "angle" trick with some 2 1/2 pipes.  For the most part you will find that the only area you will need some bending or angling is pass the rear cross beam to the muffler.  I didn't like how the pipes are seen with the bend so I decided to angle the pipes instead and just weld the joint.
