Author Topic: Trying to hardwire V1 into 318is...  (Read 2410 times)
MikeK
« on: September 14, 2007, 01:51:37 PM »
~on the left is the phone line
~on the right is the 318 Check Panel
??? ~~ Which wires do I tap into to get this thing hardwired?
Thanks guys.
« Reply #1 on: September 14, 2007, 08:43:42 PM »
You can tap the green/white wire, it is +12V in start or run off of fuse 10, 7.5A. The violet wire is hot all the time, the brown/black one goes back to the SRS diagnostic module, and the brown/violet one goes to the seatbelt warning timer.
EDIT: Looks like you'll have to figure out a ground some other way, maybe pull a new wire?
