Okay, I for one scan through some of the reading. Here's my two cents. If your a/c system has not been opened I mean broke a line or taken the compresson out and it is not cold. Have the system vacuum, the shop that will do it will tell you if there is a leak because they can't maintain the vacuum. Then get some oil, that should be the first thing you do. Because if you have negative vacuum the system will suck up that oil for the compresson. Then convert the system. Oh, I am taking all this from my personal experience. This 1991 318is A/C is cold even when the humidity in MD is 90% and heat inex is 105. By the way mixing the two R12 and R134 is not a doable.
