Suspension diagram
Author Topic: Suspension diagram  (Read 4091 times)
FloridaE30M42
Suspension diagram
« on: October 29, 2007, 04:08:02 PM »
Anyone know where i can find a diagram or cross section of the whole front suspension?
EN318isPDX
Suspension diagram
« Reply #1 on: October 29, 2007, 04:26:34 PM »
Quote from: FloridaE30M42;36818
Its in the Bentley for E30. If no one else posts it ill get it scanned when i get home from work
FloridaE30M42
Suspension diagram
« Reply #2 on: October 29, 2007, 06:27:08 PM »
Thanks I appreciate it
Spec 2
    • http://www.pnwriders.com
Suspension diagram
« Reply #3 on: October 30, 2007, 03:30:02 PM »
This Bentley manual sounds like a good thing to have...
I'd also like to see the diagram if you can post it.  Thanks!
Bunta
Suspension diagram
« Reply #4 on: October 31, 2007, 07:24:58 PM »
Front
Rear
EN318isPDX
Suspension diagram
« Reply #5 on: November 01, 2007, 10:25:14 AM »
Thank's Bunt It seems that my scanner is broken! Hope it can still print
FloridaE30M42
Suspension diagram
« Reply #6 on: November 05, 2007, 09:25:14 PM »
Is this Setup the same as other E30s including 325's?
sumyungguy
  • b.wood
    • http://www.shutterflick.com
Suspension diagram
« Reply #7 on: November 06, 2007, 12:05:39 AM »
Are you wanting to use those for what I think you are?
brad™
KenC
Suspension diagram
« Reply #8 on: November 06, 2007, 12:11:44 AM »
Quote from: FloridaE30M42;37235
M3 front sway bar linkage is different.
FloridaE30M42
Suspension diagram
« Reply #9 on: November 06, 2007, 01:20:03 PM »
Quote from: sumyungguy;37239
What exactly do you think i will be using them for?
