Author Topic: Running Rich?  (Read 3740 times)
sawdog
Running Rich?
« on: November 14, 2014, 04:36:20 AM »
Hi I am new to this club but I was on the "BMW Digest" years ago.
 We now have a '94 318i auto (100k mi) which overheated when the top plastic radiator hose flange broke and instructions to driver about watching temp gage were misinterpreted, after fixing and refilling coolant it seamed to be not running on #1 cylinder (pulling plug wire caused no change in idle).  Based in pervious experience, I (mistakenly) assumed bad head gasket or valve.  I bought gasket set and head bolts then pulled head ( a PITA job took 3x longer than on my old '84 318 / m10) and found everything good (valves, valve seats, head gasket, head flatness, cam lobes, etc), cleaned head, top of pistons, intake manifold and reassembled, replaced oil and coolant and it started right up with #1 showing the same symptoms.  Upon further investigation found #1 was (at least at idle ) running too rich to fire. #1 injector looked good when I had head off.  Have not tried switching injectors yet.  Coolant temp sensor for ECM reads good per ohmmeter.  After sitting off for 5 minuets fuel rail still held pressure.  Any Ideas?  TIA, David
colin86325
Re: Running Rich?
« Reply #1 on: November 14, 2014, 08:34:41 AM »
Try switching your ignition coils around to see if you have a dead coil on #1.
SkidMark
  • ex pro bmw wrench.. 15 yrs bavarian auto haus
  • OO==[I]==OO
Re: Running Rich?
« Reply #2 on: November 14, 2014, 08:46:20 AM »
Sounda like a dead coil or a stuck open injector to me...skid
1970 BMW 2002, 1988 BMW 325ix, 1979 BMW 320i m42 powered race car, 1969 BMW r75 cafe bike, Greasy fingers, Empty bank acct, Pissed off wife, Unhappy dog, Filthy garage.
sawdog
Re: Running Rich?
« Reply #3 on: November 14, 2014, 01:02:09 PM »
Sorry to not mention it in first post but the coil appears to be good, disconnecting wire from coil with engine running pulls an approx. 1/2 inch spark, also connecting to an out of engine spark plug shows a good spark, am running Bosch +4's.  This car has a 4 coil pack ( hung off shock tower) and other than rewiring multi-prong connector there is no easy way to switch coils.  Also when I remove the oil filler cap, allowing in extra un-metered air via valve cover vent hose the idle picks up.      TIA again David
Tgoode318
  • -Receive: 11
Re: Running Rich?
« Reply #4 on: November 14, 2014, 06:16:04 PM »
Have you tried getting any fault codes from her?
« Last Edit: November 14, 2014, 06:17:48 PM by Tgoode318 »
-'94/05 M42 Convertible
-2001 330CI M Package
-2016 M4 Competition
