Author Topic: Bad running at high revs  (Read 1858 times)
Turbotodger
« on: May 11, 2014, 04:17:44 AM »
Hi all
First time posting on hear so sorry if this is in the wrong part or I have done anything wrong.
Right I have a e36 318ti 1.9 that I use as a track toy / drift car and lately it has started running bad at 5500 RPM onwards but only when the engine is hot enough to activate the fan before this it pulls like a train at first I thought the RPM limiter was cutting in early because that is what is sounds like but I can power through this it just runs ruff so I changed the fuel filter thinking it was lack of fuel but no joy I then thought it was a slight misfire across the cylinders so changed the plugs leads and coil but nothing has changed so now I'm thinking air mass although I have unplugged it and nothing really changed apart Fromm running a bit lumpy at idle I have ordered one for Monday and that's as far as I have got
Has anyone else had this problem or can help me solve it
Thanks Shane
booxzzy
Re: Bad running at high revs
« Reply #1 on: May 16, 2014, 02:30:16 PM »
might be some kind of fuel starvation,your fuel pump going bad or maybe injectors clogged
