Author Topic: failed CA smog inspection for OEM "headers"  (Read 8024 times)
Re: failed CA smog inspection for OEM "headers"
« Reply #15 on: August 30, 2013, 12:49:07 PM »
Plug your SMOG results into this calculator and report the AFR's.
http://www.smogsite.com/calculators.html#lambda
It sounds like you are running rich if CO and HC are really high. Does the exhaust smell rich/gassy when idling with a fully warmed up engine? Is your fuel economy 20MPG or less? If so, you may have a new O2 sensor in your future. A new CA-legal cat should run you $250 (cat + welding it in). If the original one is still in there, well, it sure made it a looooong time!
« Reply #16 on: September 03, 2013, 04:24:10 PM »
The mechanic is wrong.  There are exemptions for BMWs with exhaust headers.  The Dinan M5 has an Executive Order:
Quote
EO: D-176-24  View PDF
EO Date: 2004-01-27
Manufacturer Name: Dinan Engineering, Inc.
Device: Header System
Device Type: Exhaust System / Exhaust Modification
Part_Number:    Model_Specification:    Modification_Allowed:    Remarks:
D360-6500     2000-2003 BMW M5 4.9L          The Dinan Header System is a pair of long tube headers manufactured out of 16 gage stainless steel. The headers are designed in the configuration of 4:2:1. The oxygen sensor remains in the stock location at the collector of the exhaust system.
D360-6510     2000-2003 BMW Z8 4.9L          The Dinan Header System is a pair of long tube headers manufactured out of 16 gage stainless steel. The headers are designed in the configuration of 4:2:1. The oxygen sensor remains in the stock location at the collector of the exhaust system.
I know it's not for the M42, but if Dinan could get an exemption for what is absolutely a "performance header," there must be some room for common sense here.  It's easy enough to find a few listings for the early-style header.  I'm willing to put up a valid Ebay posting for you if you need one.
If that fails, can't you also file an appeal on the Visual Inspection?  I found this site, permitting reports to be filed for this sort of gross incompetence:
Quote
You may call DCA at 800-952-5210 to speak with a consumer information specialist about filing a complaint or to obtain pre-printed complaint forms.
Other Complaint Related Links:
Might be worth a half-hour or so, if just to resolve one point of your emissions test.  I'd suspect that the "burden of proof" is on the mechanic, not you.  Personally, I'd get a lawyer buddy to write an official letter for me.  I'd be completely willing to waste a day in small-claims court if the shop refused to back down.  In my experience, bullies will always step down if the costs are too high, especially bureaucratic ones.
California is really odd about these sorts of things, aren't they?
[/list]
« Last Edit: September 03, 2013, 04:25:58 PM by DesktopDave »
« Reply #17 on: March 17, 2014, 06:12:40 PM »
Topic split for RomeoMike's new problem. New topic is here:
http://www.m42club.com/forum/index.php?topic=18215.0
