Author Topic: wheel nuts scrape.  (Read 4071 times)
sjoerd
wheel nuts scrape.
« on: July 03, 2014, 04:10:33 AM »
when i put my lenso bsx wheel on the rear richt wheel nuts hit somthing inside the rotor, i changed my wheel nuts from front to back but still the right rear wheel uts hit somthing and when i drive it's erry loud an anoting 'tik tik tik tik' but when i pull my E-brake fully op it doesn't make a sound enemore.. can someone help witj what i should do? cut a piece from my wheel nuts :s? tighten my E brake moren because it doesn't doe mutch now. other suggestion? witj my 15" style5 wheels it doesn't hit anythinh en drives fine.
sjoerd
Re: wheel nuts scrape.
« Reply #1 on: July 03, 2014, 10:39:21 AM »
fixet
