Hi Guys,
Just bought an old 318Ti, which runs very fine at revs but acts like hell stationairy or driving away in first/second. It stutters, has huge revdrops and the stuttering/juddering when driving away really makes it undrivable.
I suspect the AFM myself, so I unconnected the sensor and it does improve greatly, but off course running without afm the car has almost no power left. I don't know what the engine management does when the afm is disconnected: It probably guesses the air flow, but is it still looking at the other measurement values? Ergo: When I disconnect the AFM, Could it be that the system doesn't look at another sensor, f.i lambda value?
However I guess the motor doesn't run on lambda at a cold start? My issue happens both at cold and hot.
So what do you guys think? Should I just replace the AFM or is there a way to mend it? Does it sound like a common problem?
If there is a solution, I guess I would be able to solve it myself.. I have a degree in automotive engineering, but skipped from carburettor-vehicles to electric cars so have almost no experience with fuel injection.
Many thanks in advance for your help!
Regards,
Niels
