Author Topic: Sway bar set up  (Read 5143 times)
selespeed
Sway bar set up
« on: January 09, 2014, 12:30:45 AM »
hi;
I have a set of H&R anti-roll bars on my e30. the front is set to hard (innermost hole) while the rear has it at the mid (center hole). the handling in corners, while improved is a little twitchy under braking. it tends to skate a bit not in straight line. I don't like this feeling.
has anyone of you experienced with sway bar settings and which is most balanced? please share your experiences.
thanks.
selespeed
Nick_318is
  • -Receive: 11
Re: Sway bar set up
« Reply #1 on: January 09, 2014, 09:54:06 AM »
I have a set of Ireland engineering 22/19 adjustable bars.  I have the front set to medium and the rear as soft as I can and the car seems to be well balanced. I would suggest you reduce the rear bar and see what happens.
Generally these are your options for changing the handling characteristics of the swaybar.
Understeer: reduce front or increase rear anti-roll/ sway bar settings.
Oversteer: increase front or reduce rear anti-roll/ sway bar settings.
You may also want to check your alignment something there could be out of whack.
selespeed
Re: Sway bar set up
« Reply #2 on: January 09, 2014, 08:00:41 PM »
thanks. I did my alignment a few days ago when replacing a somewhat loose balljoint on the right side. the front has +2.4mm toe and -ve camber 2.35 (I have lowered springs). I played with the toe in and it is not due to this. but the twitching under braking is pronounced with the sway bars. I think I will change the settings today. I will change to front medium/rear soft to see how it behaves
I almost bought the IE bars but I heard the rear would produce noise because it's using clamps. is this true in your case?
Nick_318is
  • -Receive: 11
Re: Sway bar set up
« Reply #3 on: January 10, 2014, 02:55:46 PM »
I'm not sure, I never really noticed that much more noise with the additional trunk reinforcement mounts that the Ireland bars have.  My car has a lot of suspension components that aren't stock so it always seems fairly noisy these days.
selespeed
Re: Sway bar set up
« Reply #4 on: January 10, 2014, 06:58:29 PM »
do you do tracking? if you don't and you use a lot of PU bushes, it will weaken your car. e30 is old chassis and the metals are not as strong as when they are new.
e30 is my daily car. I use all STANDARD rubber bushes from BMW. they are more pliant and forgiving and hence protect the body. because I do a lot of street driving and enjoy fast twisty roads. over here, we can drive a lot faster than in usa.
Nick_318is
  • -Receive: 11
Re: Sway bar set up
« Reply #5 on: January 11, 2014, 09:07:57 AM »
Yeah I track the car a few weekends a year, it is my weekend/fun car not a daily so I probably only put 3-5000 miles on it each year.  I have powerflex bushings everywhere but the swaybars and control arms, I'm not too concerned about it at this point.
How did the changing the sway bar settings work out?
selespeed
Re: Sway bar set up
« Reply #6 on: January 13, 2014, 09:19:16 AM »
I did not have the time to do this yet. but I am looking for a set of engine brackets and motor mounts and this is real hard to find (left bracket). what is a good brand of brake pads for street use - cheap and good and long lasting lol
I have not tracked with this car yet. but tempted to do. I tracked a few times in Malaysia using my alfa 156 selespeed
