Author Topic: spring and shock recommendations  (Read 14243 times)
xxlbimmer
« Reply #15 on: December 06, 2011, 07:10:22 AM »
My 2 cents for what it is worth. BC racing kit 10k front (540 lb) 14k rear (780 lb) 25mm front IE bar and no rear bar. The stiff springs in back keep you from rubbing but "act" as sway prevention. Will handle awesome and drive all day, a bit stiff but compliant. Get the Swift springs( slight upcharge) and get a better ride.
Your milage may vary. Not to be used in conjunction with any other offers. Only one vehicle at this price. All rebates retained by the dealer.
G-Man
« Reply #16 on: June 10, 2012, 11:58:16 PM »
Are there any specific springs for the E30 318/318is or are they geared toward E30 with a M20 motor? There is a weight difference between a 325i and 318i and I wonder if spring manufacturers take that into account since E30 318i was manufactured at the end of the production run (for the North American market).
G-Man
G-Man
74 2002tii (many mods)
91 318i
98 Tacoma prerunner, parts hauler, winter beater
Warsteiner
  • -Receive: 21
« Reply #17 on: September 06, 2012, 05:28:40 PM »
Just got off the phone with H&R......The spring set to have is the 29964. This is a little softer in the rear but overall the same rates as the 50404-55 and will sit lower on our E30 318is. It's actually only listed for one application and that is the 84-85 E30 318i. If you happen to find an E30M3 that is changing suspensions then look for 3/1 HA for the rears and 3/1 VA with a white paint mark after it on the fronts. It is the 29664 Kit.
The race springs 50404-88 rates are 315 Front and 570 Rear.
I know I have seen someone post the 29664 is the way to go so whoever that was .....you were right:-)
HTH....
Cheers,
~Ralph
PumpItUp
Re: spring and shock recommendations
« Reply #18 on: November 03, 2013, 05:25:44 AM »
Same thing I was wondering. And what happens if I put springs from a "heavier" 318ic/325ic convertible and unique struts/shocks from a 325ix. Will the car under or over-steer, ride soft or hard, sit high or low?
Correct me if I'm wrong with this summary: The OEM Sachs/Boge struts/shocks are unreliable under aggressive driving but technology has moved on since 1991 and Boge now makes "Turbogas" aka Sachs Advantage which can make your car feel like new, but there are also other lines of struts/shocks to look into to replace OEM like Bilstein "HD" (Heavy Duty), or if you're trying to save money Sachs Super Touring and Bilstein Touring Class which are about half the price of HD's.
If your car is lowered with shorter springs you can upgrade to Bilstein Sports or Koni Sports. Or try your luck with less expensive options, like Tokico HP's or if you are really desperate, KYB, Monroe or other generic garbage which will ride badly and not last very long. On the other hand if you have money to spare you can look into a race style adjustable coil-over suspension. Loads of companies offer coil-over kits for the E30, usually between $1,000-$3,000. Such a suspension setup can make the car handle as if on rails but it will not be comfortable on a daily basis, especially on bad roads.
PumpItUp
« Reply #19 on: November 05, 2013, 07:41:45 PM »
I wish there were more options for a ride similar to stock, I can't find (or afford) e30 m3 springs, I could cut the springs and surely make things worse. Ireland sells cheap drop hats (another brand also sells them but for $180 or so) but those only work for the front and what's the point of lowering half the car.
Here are the Bilstein options: http://cart.bilsteinus.com/search/mmid=2130/drivetype=RWD
And info from Sachs-Boge: http://webcat.zf.com/index.asp?PKW=1&KHERNR=16&KTYPNR=28&KMODNR=290&KAT_KZ=P,N&EINSPNR_ART=32&ARTNR=170+142&LASTPAGE=nc2_teile_info.asp
"Sachs Advantage" OEM replacement
http://www.fcpeuro.com/products/bmw-shock-absorber-rear-e30-oem-105-750
« Last Edit: November 08, 2013, 01:23:36 AM by PumpItUp »
