Author Topic: Switched +12V Source under the dash?  (Read 4612 times)
Wiker Man
  • My Car: BMW 1993 318is
« on: November 25, 2012, 06:01:08 AM »
Hi, I'm David, Its good to have found a forum dedicated to m42, I have a 1993 E36 318is, actually bought it off an uncle of mine, I love working on the car.
Anyway, this maybe a re post but I am looking for a Switched +12VDC Source under the dash to hardwire some devices. It should be Hot when Key is in 1 or 2. The Cig lighter and Glove Box light is is always Hot and interferes with sleep mode.
I have done a lot of searching and I am getting Mixed responses from the web and this forums. Nothing says it Clearly...
Violet/White stripe - most likely switched 12vdc
Purple w/ white stripe
Red w/ green stripe
Red w/ yellow stripe
Known Switchers source that can handle a few low draw devices like my Gauges, Ipod charger, V1 Rader, GPS, without runing the circuit..
Some input would be appreciated. Thanks
keflaman
  • -Receive: 35
« Reply #1 on: November 25, 2012, 06:34:32 AM »
Hi David and welcome to the forum!
If you don't have it, here is a link to the WDS for your car: http://wedophones.com/Manuals/BMW/1993%20BMW%20318i%20-%20318is%20-%20325i%20-%20325is%20%20Electrical%20Troubleshooting%20Manual.pdf
I'd recommend studying section 0670.3 - Fuse details (starts on page 36) and pick one which is "hot in accessory, run and start".
It's been a while since I last worked on an E36, but there's plenty of corporate knowledge here and someone who can answer better than me will be along shortly.:)
Wiker Man
« Reply #2 on: November 26, 2012, 12:44:39 AM »
Thanks pal, I looked into the 0670.3, it gave me some basics but yet not very clear how to proceed, also my car doesn't have a sunroof. But I will probably borrow a Multimeter and test out some wires this weekend.  I was just curious if lets say the Violet/White Stripe wire turns out to be say ACCY on, then should I be okay running my Gauges, GPS, Rader Dectetor etc devices hardwired without damaging or breaking anything?
I also have a foglight set to install, will post a new topic on it now.
