DISCUSSION
Engine + Driveline
Strange timing chain guide
Topic: Strange timing chain guide (Read 4070 times)
pierre02ti
December 23, 2012, 03:41:05 PM »
Rebuilding a defective M42 1991 engine with parts from an engine purchased with no history.
The timing chain long guide on right hand side from the spare engine looks much better than the original but is very different: all black plastic while the original is metal with plastic inserts.
I guessed it was an upgrade as all dimensions fits correctly.
# in the rail of the "new" one is 11311727697 if I am right.
After the installation, I search to conform what I have but cannot find any reference in Realoem or Google.
What do I have? Picture attached
Pierre
pierre02ti
Forget about it Found the answer
December 23, 2012, 04:19:28 PM »
Found a picture that shows this new design.
Pierre
colin86325
Hero Member
-Receive: 15
December 24, 2012, 08:11:34 PM »
The M42 timing chain guide has been supeceded to the the M44 design shown in the picture. You need to use a different mounting bolt (or two??) with the new design. You have to set the mounting depth with the new bolt so that the chain passes through the center of the guide.
Administrator
Legendary
-Receive: 33
December 24, 2012, 09:47:05 PM »
Make SURE that the top bolt in the guide is 45mm long. The updated plastic guide is a newer, improved version, and the adjustment sleeve is 5mm longer. The old 40mm bolt will just strip out and wear its way through your aluminum timing cover!
Visit
HERE
for a plethora of 318iS stuff and some other randomness. Would you say I have a,
plethora
, of pinatas?
DISCUSSION
Engine + Driveline
