Author Topic: Control arm and tie rod replacement  (Read 3789 times)
Bimmer805
« on: June 24, 2012, 02:59:18 PM »
Hi i just replaced my control arms and tie rods. when i was finished i notice the when i put one wheel straight. the other wheel is turn inward. and if i straight out the other side. it also does the same thing? what do i do now?
Nelson_40
« Reply #1 on: June 24, 2012, 06:42:12 PM »
Simply get an alignment or adjust the tie rods yourself to get it closer to spec.
« Last Edit: June 24, 2012, 06:49:43 PM by Nelson_40 »
Geoff
« Reply #2 on: June 25, 2012, 06:23:49 AM »
as above notes, get it aligned.   in the future when replacing front end stuff like that,  measure how much threads are showing,  or count how many turns out the tie rod is on your old stuff, then when you install the new stuff it will be very close to what it should be.
                                                              Geoff
Bimmer805
« Reply #3 on: June 26, 2012, 10:19:32 PM »
cool thanks guys everything is back to normal. shes back on the road now
