Author Topic: Need Base .msq  (Read 3555 times)
Damon in STL
Need Base .msq
« on: May 27, 2012, 04:12:34 PM »
Hi,
Does anyone have a base .msq file using EDIS4 they could share?  I've got my base code from my s14 usint a 30-1 wheel....and I've not figured out how to change it to the 60-2 wheel.
TIA
Damon in STL
p.s.  Once I get the base engine running I am going to install my turbo components.....so, a base turbo code would also be helpful!  Thanks!
« Last Edit: May 28, 2012, 09:23:22 AM by Damon in STL »
Damon in STL
Need Base .msq EDIS4
« Reply #1 on: May 28, 2012, 09:18:56 AM »
Quote from: Damon in STL;112820
Hi,
TIA
Damon in STL
Looks like my EDIS system which I had running my s14 is not a plug and play on the M42.  EDIS must have the 30-1 trigger wheel and the stock 60-2 will not drive EDIS4.
Oh well.....back to soldering....
Still would appreciate a base .msq
Damon in STL
« Last Edit: May 28, 2012, 09:24:24 AM by Damon in STL »
Damon in STL
« Reply #2 on: May 28, 2012, 10:08:04 AM »
Damon in STL
« Reply #3 on: June 05, 2012, 09:06:52 AM »
Got the engine running this weekend on MS2 v3.  Added a second ignitor and used the coil pack from the EDIS4 in wasted spark mode.  The ignition and fuel code I'm currently using is from my s14 code.  Still looking for a good M42/M44 base code.
Damon in STL
