Author Topic: Changing fluids  (Read 1898 times)
lqbanotxano
Changing fluids
« on: February 11, 2012, 06:57:26 PM »
Has anyone noticed any difference in the operation of the vehicle/engine/trans etc....after changing the fluids? Especially if done so after many miles...like 100,000 or more.
Have you noticed the heater warming faster or lower engine temperatures, after coolant flush/change? Or, the steering working different after the change of power steering reservoir/filter & ATF flush?
Any noticed difference in the operation of the clutch or brakes, after a brake fluid flush?
I am getting ready to do all of the above & was just wondering.
1993 318is 5sp / gen 3 Mustang injectors / Mark D 91/7000RPM / Z3 shifter / Ford O2 Sensor
Changing fluids
« Reply #1 on: February 12, 2012, 09:20:45 AM »
Nope. Maybe just a slightly harder brake pedal.  I end up changing most annually, except for coolant maybe every two years or so.
Oh - except for the transmission.  I have an ATF (yellow?) label G240 & tried synthetic 75w-180? gear oil...it never felt right.  I went back to ATF and it's been "back to normal" ever since.
deansweet
  • -Receive: 12
Changing fluids
« Reply #2 on: February 12, 2012, 10:29:16 AM »
I noticed the car runs a bit cooler after the replacement of coolant, thermostat and water pump but that is not something unexpected.
