Author Topic: E36 318is Need an engine. Replacement question.  (Read 2508 times)
lostmenoggin
« on: February 01, 2013, 11:37:29 PM »
Can I put any M42 in my 7/1992 318is? I need an engine and I plan on using the wiring harness and ecu that came with the car and was wondering if any of the different year M42 engines would work. Thanks.
93 Nissan 240sx - needs S14 notchback block
92 BMW 318is - needs everything
92 Yamaha FZR 600 - go fast, save gas
96 Chevy K3500 crew cab long bed 4x4 - the skool bus
Geoff
« Reply #1 on: February 02, 2013, 08:47:46 AM »
different years  will work,  but probably not without mods.  the early ones for e-30 use a different ecu and different sensors in the head.  these engines run w/out a knock sensor.  The later ones than yours may work, but there were differences along the way with the belt system and maybe other stuff I am not aware of.   a true plug in motor with no mods at all would probably have to be the same type as yours.
        Geoff
e3091318is
« Reply #2 on: February 12, 2013, 02:49:09 AM »
I have a 1991 318is E30 and I am attempting to put put in a M42 from a 1995 318i sedan.  Looks all the same.  Only doing the block and switching everything else out.
2000 Mercedes S500 (Sold)
2001 BMW 325CiC (Sold)
2003 Honda Accord Coupe EX-L V6 (Sold)
2001 Audi A6 2.7T (Sold)
1984 318i Coupe (Sold)
1991 318is Coupe (Current Project)
e3091318is
« Reply #3 on: February 14, 2013, 01:53:08 AM »
Quote from: Geoff;119802
        Geoff
I am guessing it would be easiest just to put in the original sensors and keep the original ecu?  This may also allow you to delete the anti-knock sensor too.
