Author Topic: Lots of misc e30 parts fs.  (Read 5014 times)
Naked Assault Gerble
« on: August 04, 2011, 02:51:38 AM »
Cleaning out my garage of parts that I have collected over the years, all prices are negotiable
-91 318is parts
-Motronic unit 0 261 200 175 $50
-Throttle body $30
-Air flow meter $25
-Crank positioning sensor $25 SOLD
-Coil Pack $30
-4 exhaust valves *New in box* $10 ea SOLD
-ICV $20 SOLD
-Water pump *New in box* $40 SOLD
-Gauge cluster with 193k showing $50
-Timing Chain *New in box* $40 SOLD
-Flywheel (manual duel mass) $75
-Complete gasket set for top end (Head, intake, exhaust, throttle body, timing case, valve cover, spark plugs, valve cover bolts, water pump, ect, lower oil pan with the set) *New in box* $100 SOLD
-Getrag 240 5 speed tranny with 130k miles $200
-Manual drive shaft $50
-Random m20 parts
-Meyle CSB and bracket *New in box* $25
-Window motor screw style $15
-Window motor scissor style $15
-Air Flow Meter and box $40
-2 strut mounts *New in box* $50
-13 button obc $10
-AC/Recirculate switch $10 SOLD
-2 window switches $5 ea
-Rear defrost switch $10
-2 window locks $5 ea
-Hazard Switch $5
-Heat and AC knobs $5
-Hellrot red brake cooling intake thingy and boot (passenger side) $5
-Driver side inner door handle $5
Was going to see if any of you local folks wanted any of it first before I toss it up in the general fs section.
*edit*
Just found a complete shield style body kit in my attic (side skirts, front and rear bumpers made out of fiberglass) no idea how much it is actually worth its new in the box $300 perhaps?
« Last Edit: August 26, 2011, 06:23:23 AM by Naked Assault Gerble »
a930rocket
« Reply #1 on: August 07, 2011, 04:44:26 PM »
Do you have the brake ducts?
1991 318is
1987 911 Turbo
« Reply #2 on: August 08, 2011, 03:15:26 PM »
Quote from: a930rocket;105990
Yes I do.
a930rocket
« Reply #3 on: August 09, 2011, 05:13:51 PM »
Do you have a pix of them?
I'm not sure if it's part number 2 or 5 (Left Side) although they look the same except for the louvers.
http://www.realoem.com/bmw/showparts.do?model=AF93&mospid=47305&btnr=51_1865&hg=51&fg=75
Mine has the louvers.
Email me at: a930rocket at bellsouth . net
« Last Edit: August 09, 2011, 05:31:48 PM by a930rocket »
1991 318is
1987 911 Turbo
deansweet
  • -Receive: 12
« Reply #4 on: August 11, 2011, 01:45:03 PM »
Check PM please.
thx
« Reply #5 on: August 13, 2011, 11:57:17 AM »
Ygpm
« Reply #6 on: August 15, 2011, 10:07:42 PM »
Body kit pics for those who were interested
« Reply #7 on: August 20, 2011, 05:48:11 PM »
Bump for last shots everything goes to fleabay on Monday.
c2daloc
« Reply #8 on: August 23, 2011, 12:11:26 AM »
hey,i am interested in purchasing the AFM.how do we go about this?new here!
« Reply #9 on: August 23, 2011, 07:20:33 AM »
Click his user name, select "Send a private message..." and be prepared with your Paypal account?
Be sure to leave feedback for the seller in the appropriate forum...
