Author Topic: My new ignition coils.  (Read 2726 times)
romkasponka
« on: June 08, 2011, 05:21:28 PM »
So today I test fitted my new ignition coils and there was only one cylinder head cover modification - enlarged holes to 28 mm to accept ignition coils .
Ignition coils are from newer BMW (new cost about 30$).
P.S. Ignition coil is fitted without gasket under cylinder head cover, so coils will be little bit less protruding from the head than it looks now.
« Last Edit: June 08, 2011, 10:17:57 PM by romkasponka »
E30 318is M42
E36 318is M44
M5wanaB
« Reply #1 on: June 08, 2011, 11:09:55 PM »
does it take the same plug? any other modification? What is the stock bore of the plug wells?
« Reply #2 on: June 09, 2011, 07:25:54 PM »
Which newer BMW?  All of them?  Are wiring connectors the same?  That's a deal, if so.
romkasponka
« Reply #3 on: June 10, 2011, 03:28:47 PM »
« Last Edit: June 10, 2011, 11:38:44 PM by romkasponka »
E30 318is M42
E36 318is M44
romkasponka
« Reply #4 on: June 10, 2011, 03:32:01 PM »
As I know all newer BMW, check part catalog. Plugs are diferent...
Stock bores are 25mm as I remember.
« Last Edit: June 10, 2011, 11:37:31 PM by romkasponka »
E30 318is M42
E36 318is M44
