Author Topic: Oil in Spark plug holes? Valve head gasket?  (Read 2927 times)
n.wesl
« on: November 28, 2010, 04:44:02 PM »
I did the COP conversion today and discovered my spark plugs are covered in oil. It's not a little either. When I stick a towel down in the hole it comes up dripping. Cleared it out enough to have the spark plugs not be covered but what's causing this? Is it the "valve head gasket"? If it is how do I replace that? Thanks
DPINEDA
« Reply #1 on: November 28, 2010, 07:06:35 PM »
Check your valve cover screws. Might be loose. Don't over tighten or you will strip thread on head!...
1991 E30 318is Daily Driver
2006 R171 SLK280
2002 W203 C240
n.wesl
« Reply #2 on: November 28, 2010, 08:50:27 PM »
Thanks. Any idea what the foot pounds should be?
DPINEDA
« Reply #3 on: November 28, 2010, 09:01:47 PM »
Bentley service manual has tightening torque of 10 Nm (89 in-lb).
2006 R171 SLK280
2002 W203 C240
n.wesl
« Reply #4 on: November 29, 2010, 05:03:43 PM »
Alright, I'll check it. Thanks
n.wesl
« Reply #5 on: November 29, 2010, 06:56:08 PM »
So I checked them today. About 6 of them seem to be stripped out. Uh oh. Tightened the others down though and seemed to show an improvement.
