Author Topic: Removing 22mm harmonic balancer bolt  (Read 10891 times)
Faceman
« Reply #15 on: October 18, 2010, 09:18:23 PM »
I just did this today with a 1/2 impact gun. The one thing that I did before I started was lube it down with PB blaster for a day. I have a ingersol rand that put out 600lbs in reverse and 300 going forward. Had no problem getting it out  Has anyone seen a damper separate from a pulley, what ever the glue/bonding agent that was use to hold it in place decided not to hold anymore.
mr.vang
« Reply #16 on: October 19, 2010, 12:27:44 AM »
i always use a chain with teeth to hold the crank pulley. it works great. i think autozone have it.
fs: air bag model knee panel, bmw tools, ects
ScottJ
Damper/pulley separation
« Reply #17 on: October 19, 2010, 10:45:34 AM »
Pretty rare problem, but does occur when the rubber bonding the toothed wheel to the pulley ages and lets go.  Unfortunately a new one from BMW is $700+, so a used one is the way to go.
e30boarder
« Reply #18 on: October 19, 2010, 10:52:46 AM »
I'm still working on the block. I have a buddy helping me out. He looked at one of the crank bearings and said they were in good shape. Should I still order new bearings for the whole crank?
