Author Topic: im selling my s50  (Read 2165 times)
algonequin
im selling my s50
« on: August 12, 2010, 12:07:27 AM »
10/95 built 110k miles
The engine had a head gasket failure was removed
Was going to be swaped into a 91 318is but due to lack of funds now is for sale
It is compelty appart (minus the bottom End) Has a New-er Cylinder head  from a 98 M3 OBD2 that was 100% re done by Rick Kemph in San pedro
3-way valve adjustment, new valve stem seals, re machined, pressure tested and flow matched
also Includes a E36 Oil pan and Pick up, aswell as E34 Pan and pickup
OBDII Pink top 21.5 lb injectors aswell as green 17.5lb injectors
OBD1 Harness,OBDII starter,OBDII alternator,Power steering pump,reservoir,
Motor mount arms, OBDII headers,every single nut and bolt
This is a perfect Engine for a weekend project or Turbo build
All the engine needs are, Timing Chain guides, most seals and assembly
I will also include a 95 M50 w/ Unknown milage and unknown cond but good complete for parts
I'm asking 1500
http://socale30.com/forum/viewtopic.php?t=5335
