Author Topic: Do all M42s sound like lawnnmowers?  (Read 6356 times)
M42boy
« Reply #15 on: June 19, 2006, 09:18:46 AM »
Mine doesn't sound like a lawnmower, but you hear it whine a lot.  With a good exhaust or muffler, this can really transform it.  I want to put on an exhaust when I have money again.
sheepdog
  • Site Admin
« Reply #16 on: June 19, 2006, 01:13:44 PM »
Put in a new timing chain tensioner, that cleans up a lot of the rasp in the midrange.
Another thing for sound, put just a decent flowing cheapie muffler and cut the air box on the fender side.
This will give you a decent sounding setup, at least in my opinion.
One last thing, if your t-chain is EXTREMELY stretched, DO NOT put a tensioner in. I suspect that is what led to my chains failure.
 Put in a new chain first.
« Reply #17 on: June 19, 2006, 01:50:14 PM »
I would be interested to hear some peoples' exhaust with the 'economy' solutions.  I have heard a lot about the Dynamax Super Turbo as well.  Though I am running SuperSprint, it is getting to be 7 years old now, and it will probably need replacing in the next few (though it is still rustless and ni very very good condition).  Since I cannot get a new one for $400 anymore, I will need an alternative.
The engine whine has been attributed to the timing chain guides/slippers.  It is nothing to be concerned about, it is just the chain whizzing through the plastic/rubber guides.
A neighbor had a 1991 Miata, and it had pretty loud lifter tick.  I always though it was gonna blow or something, and the guy barely maintained it, but it held together relatively fine.  So, I guess lifter tick is fine...to an extent.  If oil detergents do not fix it, you are either severely clogged up with gunk (which IS bad and will cause stuff to wear out a lot faster), or the heads of the lifters are just a little concave from wear and are noisy.  If it is the latter, then it does not put you in imminent danger.
Exhaust raspyness.  I thought that was somethign that could not be fixed.  Well, most of it was from the catalyst to cat-back flange connection.  A muffler shop years prior had mesed up the flange and it never sealed right again.  My new car has not been butchered like that, and the rasp is 95% gone.  The only other place i would think it comes from is cracks in the header welds, or a worn header gasket (at the head or downpipe).
automatic
« Reply #18 on: September 14, 2006, 10:08:53 AM »
The PO of my car got the cat back replaced at a lMidas under warranty the day before I bought it. The muffler they put on is clearly not designed for the car and the mount they tacked on the muffler has already fallen off.
Combine that with the fact it sounds like a Civic with a fart can means I need to do something about it quick.
The M42 w/ Dynomax clip on r3v is lightyears away from what I have now and i'm thinking that is the right direction for me. Anybody here have a dynomax?
http://www.r3vlimited.com/Media/Sounds/sounds.htm
MustPayDaddy
« Reply #19 on: September 15, 2006, 01:45:53 AM »
i got a dynomax.. not a bad replacement for stock. its light and the sound isnt too far off from stock.  the police never look twice when i pass by and ive had cars with loud exhaust before.  also bmwman heard me roll up so you can ask him how my car sounded...
