Author Topic: My DASC install  (Read 4413 times)
nickmpower
My DASC install
« on: May 23, 2010, 05:50:38 AM »
It was quite the hassle to get this thing to fit. I converted the engine from v-belt to serpentine by changing the crank pulley, water pump pulley, and alternator. I am not running power steering so i had to figure out a way to route the belt that would work with my setup.
Because the belt goes right in the way of the dipstick I bought a dipstick from an e36 that is curved. I had to cut a few inches off of the bottom of the dipstick so that i could rotate the dipstick to clear the belt. I had to bend it slightly also.
I added a remote resevior for the brakes since the throttle body elbow hits it. I moved it to the firewall but then had to move it again when I installed my strut brace.
I eliminated the RRFPR that the stock DASC setup uses and tuned the fueling and ignition with tuner pro. Eventually i think I am going to upgrade to megasquirt in order to get rid of the airflow meter. As you can see I can only fit a tiny filter on the car as of now.
Hodge
My DASC install
« Reply #1 on: May 23, 2010, 06:32:38 PM »
Very clean install! Well done!
1995 E36 318isc
Ryann
My DASC install
« Reply #2 on: May 23, 2010, 06:42:44 PM »
awesome.
wadhip
My DASC install
« Reply #3 on: May 24, 2010, 02:21:51 AM »
hmm... very nice !!!
HATER-PROOF
My DASC install
« Reply #4 on: May 25, 2010, 10:19:18 PM »
Clean work:>)
Romrog318is
My DASC install
« Reply #5 on: May 25, 2010, 11:05:47 PM »
very niceee!!
any power results yet? as in dyno :D
no more M42
Hey-u
My DASC install
« Reply #6 on: May 26, 2010, 12:33:27 PM »
Nice install. How do you like the power?
