Author Topic: Damn M7 x 45mm Exhaust Flange Studs!  (Read 5745 times)
hochiminh
« on: May 29, 2010, 05:39:27 PM »
I am having difficulty finding M7 x 45mm exhaust flange studs to bolt my header to my head, both online and in the local hardware stores. I called the stealerships and they want $55 for 12 studs and bolts, to which I kindly said "go to hell." I have managed to locate one place that has M7 x 55 and 45 mm bolts made of steel but am not sure if I cut off the bolt top that it will work. Can anyone confirm this? :confused: Do I need specifically expansion type bolts? Any input is greatly appreciated.
Thanks! and Happy Memorial Day!
B318M42W
« Reply #1 on: May 30, 2010, 03:02:07 AM »
I agree that 55$ for 12 bolts is pretty expensive, but i beleive that they are high quality bolts made to sustain and still work properly even when heated. I wouldn't put hardware store bolts on any engine... (well, maybe in a honda engine :p ).  But if you still want to go the cheaper route, and cut the bolts, it would be a good idea to chamfer the cut end and pass it through a die to clean up the threads.  my .02 cents...
M90 Blown M42 :cool:
PumpItUp
hochiminh
« Reply #3 on: May 30, 2010, 02:29:10 PM »
No, according to realOEM it's M7; I also verified it. I guess I should have mentioned that this was for a '91 E30 M42. Might be different for the E36 heads.
hochiminh
« Reply #4 on: June 01, 2010, 12:59:22 PM »
bump! any sites/non-dealer carriers of these studs?
PumpItUp
« Reply #5 on: June 01, 2010, 04:52:31 PM »
closes size i've found
http://www.rmeuropean.com/Part-Number/Exhaust-Port-Stud-7-X-42-mm-__11121744057_GEN_E095124A.aspx
bro don't trust realoem, for all you know its a typo or they're designed to expand. ask someone who knows what they're talking about like a bmw mechanic or a smart muffler shop. if you figure this out be sure to post
hochiminh
« Reply #6 on: June 02, 2010, 02:07:08 PM »
Thanks, PumpitUp. I went to a BMW specialist near where I live (catulpastreetgarage.com), they had 'em in stock! But I ended up paying $38 which was a ripoff still. They are identical to the ones that came out, and went in with ease. Hope this helps out people in the future.
Reference: M7 x 45mm exhaust flange stud. OEM Part #: 07129908199
