Author Topic: supercharger m42  (Read 3863 times)
manchuk
supercharger m42
« on: October 01, 2010, 02:42:25 PM »
hi im abandoning my supercharger progect goin turbo instead its in excellent shape needle bearings were inspected so they need to be repacked with grease and the roters and coating are prestine!!! i also made custom flanges for intake and exuast i also have 2 pulleys for  v belt rughly 7psi and 14 psi  i also have the original electric clutched serpentine pulley for boost on demand(if you have serp),need sleeves to go from 1/2 " shank to 5/8" for v belt(ANY farm store like princess auto or tsc carries them)....asking $500 on ebay but if somebody wants it on here ill take $450 , that way it goes to a good home with the same idea that i had . the shipping is $65 anywhere in north america
« Last Edit: October 01, 2010, 02:54:44 PM by manchuk »
manchuk
supercharger m42
« Reply #1 on: October 01, 2010, 02:50:12 PM »
pics
dvmotorsports
supercharger m42
« Reply #2 on: October 01, 2010, 03:54:40 PM »
What is required to get it up an going? ie; associated mods both externally and internally.
What EMS needs to be run?
What are the potential gains?
I'm seriously interested. Who made this kit?
manchuk
supercharger m42
« Reply #3 on: October 02, 2010, 04:49:01 PM »
-this is a project i started my self!! the red flanges are custom made .
-the one pulley is good for  6-7psi and the other is good for 11-12 (according to calculations made on the size of  our crank pulley)
- if you use the 7psi pulley you dont need computer management just a riseing rate fmu (same as dasc)but if you want more than 7 psi i would recommend a standalone or miller W.A.R chip, i also talked to a member here(bmwconnect) who can  make a custom chip with fuel and ignition maps cheap
-1 degree colder plugs are recommended
- larger injectors are also recommended over 10psi ours run at 90% duty cycle at 9 psi
-there is still some fabricateing needed like mounting of supercharger, a hub to mount pulley and plumbing to filter and intake
-i look at it this way (dasc is $3500 if you can find it and u still have to convert to v belt from serp)
-im asking $450 plus $65 shipping. you will probably have to dump another $300-$500 into it and some elbow grease so thats not bad for $1000
-no internal mods needed its proven our m42 moters can handle upto 14psi on stock internals people do it on here all the time
as for performance gains the dasc unit makes an extra 40-50hp at 7psi to the wheels, depending on what shape ur moter is in ,considering the pump is the same model as dasc just a little more efficiant you should see close to the same result
- this is a positive displacement pump so you have boost thrue the hole rpm range (no turbo lag, lots of torque down low)
-as i stated earlier i had the  pump checked out , you will need to grease the needle bearings and add supercharger oil b4 you spin it over-its in excellent shape these pumps go for $850 rebuilt and $2000 new all day long
« Last Edit: October 02, 2010, 05:00:02 PM by manchuk »
manchuk
supercharger m42
« Reply #4 on: October 12, 2010, 08:38:51 PM »
sold
