Author Topic: No start after battery drain...  (Read 2303 times)
vte30
« on: January 09, 2010, 09:59:18 AM »
So... I went outside to warm the car up yesterday morning. When I came back outside the auto door locks had activated, so the car was running with all the accessories on. Keys locked in the car meant I was locked out of the house too... fun times. Anyway, in my 5am panic, I thought if I could get the car to shut off that it maybe/hopefully would unlock. I put some vice grips on the fuel line and sure enough, it died. No unlocking though.
I called USAA and a couple hours later they came by and broke in. By that time, the battery had drained. I put a battery charger on it. This morning I tried to start it and it didn't even try to turn over. No clicking, no nothing. The accessories all worked. I put a voltmeter on the battery and it showed 12.7 volts.
Is it just the battery is toast? Maybe blew a fuse when I pinched the fuel line? Anything else I don't know about? Thanks!
vte30
« Reply #1 on: January 10, 2010, 02:01:19 PM »
Yep, it was the battery.... took it to autozone to get tested. came back with a new one and it started up fine.
