Author Topic: 2 random connector/tubes???  (Read 3770 times)
Royalratch
« on: January 06, 2010, 07:58:54 AM »
I recently deleted the throttle heater plate on my car, more for the simplified vacuum tubing than the mythical BHP increase.
I seem to have these left over:
1 AFM-type Connector
And this. This has fuel coming from it on start, I believe it's some kind of breather/vent tube? Some owners have fitted a small filter on the end if I'm not mistaken. All fuel lines are where they're supposed to be. The car runs perfectly. What's supposed to happen with this?
« Reply #1 on: January 06, 2010, 08:36:21 AM »
The wiring connector looks like a coolant temp sensor, but it's in the wrong place.  Let me look at my car to see.
That tube might be the vac canister breather.  Is there a black can in the front fender well behind the headlights?
monty23psk
  • -Receive: 17
« Reply #2 on: January 06, 2010, 09:52:24 AM »
For the first picture, under the power steering fluid should be a charcoal canister mounted to the body. On mine is has this connector. Not sure about the second pic.
Jorgeconrico
« Reply #3 on: January 06, 2010, 10:05:37 AM »
1st pic looks to connect to the bottom of the ICV. The 2nd pic looks like the hose for the brake booster but I'm not 100%
« Last Edit: January 06, 2010, 10:08:06 AM by Jorgeconrico »
Royalratch
« Reply #4 on: January 06, 2010, 10:05:46 AM »
You guys are right, first plug is for carbon Canister but this is not used in the UK.
Second pic is my main concern tho.
Royalratch
« Reply #5 on: January 06, 2010, 01:29:16 PM »
Anyone on that second hose?
92BMW318is
« Reply #6 on: January 06, 2010, 10:02:08 PM »
moar pics of the hose
nicknikolovski
« Reply #7 on: January 07, 2010, 02:39:25 AM »
Trace the pipe back to its origin and then you can see where it should plug into.
actually, it could be plumbing for the charcoal canister. explains the fuel hose.
« Last Edit: January 07, 2010, 02:44:57 AM by kowalski »
kowalski
  • El\' Duder
« Reply #8 on: January 07, 2010, 02:43:12 AM »
do your power brakes work?
Sale:
Fore Sale Thread
