Author Topic: Con rod bolts  (Read 3055 times)
forrer13
Con rod bolts
« on: November 04, 2009, 08:19:20 PM »
Guys, I need some help. I am in the early stages of a M42 rebuild and I need to know a couple of things.
First of all what socket do I use to remove the connecting rod bolts? they look like a 12 point version of the head bolts which are E12 torx, but nothing seems to fit properly on the con rod bolts.
Secondly are the crankshaft main cap bolts reusable? I know the con rod bolts and the head bolts are a one time use, but how about the mains?
romkasponka
Con rod bolts
« Reply #1 on: November 05, 2009, 12:48:28 AM »
Quote from: forrer13;80936
Buy new from BMW dealer, they are not expensive.
E30 318is M42
E36 318is M44
forrer13
Con rod bolts
« Reply #2 on: November 05, 2009, 07:44:36 AM »
OK, but do you know what socket I need to remove the con rod bolts? anyone?
romkasponka
Con rod bolts
« Reply #3 on: November 05, 2009, 09:50:25 AM »
E30 318is M42
E36 318is M44
forrer13
Con rod bolts
« Reply #4 on: November 05, 2009, 02:34:54 PM »
Quote from: romkasponka;80952
I am not shure but I think 12 point socket. http://www.southbayriders.com/forums/attachment.php?attachmentid=260418&d=1249329874
You know I think your right. I was playing around with my sockets here at work and it looks like a 10mm 12 point will work, its a bit of a sloppy fit, but I suppose with all the contact surface on the head of this bolt it should grip fine. Good, thought I was going to have to order a special tool there for a min.
