Author Topic: Problem: A noise  (Read 2735 times)
bigbody
Problem: A noise
« on: August 17, 2008, 10:55:32 PM »
When accelerating in either first or second gear there is a noise on the right side of the car near the front wheel.  It sounds like a rapid vibration/clicking sound and it only happens between ~1000 and 3000 rpms.  The sound gets worse if I accelerate rapidly and it almost unnoticeable if I am creeping along.  What do you guys think? Thank you all in advance.
AcSchnitzer318is
Problem: A noise
« Reply #1 on: August 18, 2008, 12:10:55 AM »
Clicking or raspy exhaust sound?  Sounds like an exhaust leak, but I've heard ticks like you describe from having a big nail/screw in your tire as well.
bigbody
Problem: A noise
« Reply #2 on: August 18, 2008, 12:33:41 AM »
it's definitely coming from the body or suspension in the front right side.  Maybe a squeaky/clicky noise would be a better description for the sound.
EN318isPDX
Problem: A noise
« Reply #3 on: August 18, 2008, 12:05:25 PM »
Quote from: bigbody;55066
I'd check into your tire/rim, i agree with the nail in the tire. I've had a tick tick tick noise and it was a fatty nail in my tire. If its not that then you may need a wheel bearing :(
bigbody
Problem: A noise
« Reply #4 on: August 18, 2008, 08:08:21 PM »
I think the wheel bearing diagnosis is right.  You guys know what I should expect to pay?  Any other work that should be done while the bearing is getting replaced?  How urgent is it that I replace the bearing?
xwill112x
Problem: A noise
« Reply #5 on: August 18, 2008, 09:48:35 PM »
same problem here..exept mines more of a grinding click when i hit the brakes hard...
Ich liebe meinen E30
