Author Topic: another m44 question  (Read 3601 times)
brenters
« on: July 07, 2008, 08:40:51 PM »
I have an e30 '84 318i and I was going to put in the M42 engine until I saw all the threads on here about the M44 engine.  I'm  now going to go with the M44 and would like to double check everything I am going to need to do the swap.  Based on the other threads, let me see if I got this right.
I'll need: any M44 engine (96-99, they're all the same, 318i or Z3)
             M42 wiring harness
             M42 ECU
Is that the way to go?  I was reading about how the M44 computer has the EWS immobilizer stuff in it so I should stay with the M42 computer and get it reprogrammed for the 1.9L displacement.  Is it as simple as taking it to a dealership and they know what to do?
Also, what other little things will I need, like are the engine mount brackets the same?  Different pulleys for the front end?
If anyone can give me a comprehensive idea of what all I need to make this happen I would greatly appreciate it
Brent
1984 318i with an M42 swap
2004 M3
tony92ic
« Reply #1 on: July 07, 2008, 09:53:36 PM »
Well looking at the current intake swap thread, you'll need an e30 intake as the M44 will be too tall (although I thought it was the other way around) and an e30 oil pan.
I think the M44 has different sensors, so I am not sure simply using an m42 computer will do it.
Maybe MarkD or conforti can do a custom chip for you if you can get the connections figured out. I am sure a dealer will not touch it.
There has been some threads on this before. Try the search.
Tony
92 e30 318ic - Why I am here
72 2002tii - Much modified
91 M42 - Am I a hoarder?
