Author Topic: what to change on engine while it's out of the car.  (Read 2821 times)
thejimlab
« on: May 11, 2006, 08:16:48 AM »
I will have the engine out of the car, and seperated from the tranny soon. What  sort of preventative maintenance should I do while it's out. Water pump, timing chain, and gasket or seals?
Jim
« Reply #1 on: May 11, 2006, 12:15:45 PM »
hoses
port and polish the head..
all that comes to mind right now..
M42boy
« Reply #2 on: May 11, 2006, 12:42:52 PM »
Put in all new gasket and seal sets.  I also replaced all the sensors.  There's only three I think.  Two sensors in the head and one in the back of the oil filter housing (oil pressure sender).  The crank position and cam sensors are run off of magnets and shouldn't need replacing.
I just did all this, including timing chain and water pump, guide rails, etc.  The engine is just about 100% back together now.
M42boy
« Reply #3 on: May 11, 2006, 12:43:49 PM »
Oh yeah, pull the intake manifold and go all those stupid coolant lines, fuel lines and ventilation hoses under it.  There's a mess of them!  New hose clamps don't hurt either.
Febi Guibo
  • m42 reporter
« Reply #4 on: May 11, 2006, 01:29:33 PM »
crank gear, crank seal, and oil pump...
sob!
Support M42club.com !!
