M42 wiring
Author Topic: M42 wiring  (Read 5145 times)
Vladi
    • http://www.bmwzone.ro/forum
M42 wiring
« on: September 02, 2007, 04:48:26 PM »
I've got a friend who recently swaped an E30 M42 and managed to fry his ECU. Trouble is we can't find an e30 m42 ECU anywhere, but we found 3 busted e36 m42's. (mechanical reasons)
Could we take the wiring harness and the ECU from an e36 m42 and install it an the e30 m42?:rolleyes:
Thanks!
M42 wiring
« Reply #1 on: September 02, 2007, 05:00:17 PM »
May be able to, but the E36 ECU is going to be looking for a knock sensor, so you'll need to get used to the check engine light. Too bad you aren't in the US, I have two E30 M42 ECUs sitting here.
Lund8200
M42 wiring
« Reply #2 on: September 10, 2007, 03:46:27 PM »
I have been running a E36 ECU on my E30 318iS, it made no faults for the short time it was mounted.
BTW, there is a few ECU´s for sale on http://www.ebay.de
Artem
M42 wiring
« Reply #3 on: March 13, 2008, 10:48:00 PM »
Can I flash the chip with the E36 tuned software and run it that way?
Or use the chip from the E36 DME?
-Artem
________________________
Artem Lepilov
WPI Aerospace Engineering
Class of 2008
vatos_p
M42 wiring
« Reply #4 on: March 14, 2008, 12:59:27 AM »
you can just change the wiring and the ecu with a m42 e36 ecu , and add knock sensor , change the AFM with a MAF ( the e36 uses maf ) and the car will work fine...
steer with the rear !!!
Artem
M42 wiring
« Reply #5 on: March 14, 2008, 02:33:46 AM »
Quote from: vatos_p;44757
Yea, I was kinda hoping to avoid that... I wanted to use stock wiring from an E30, but a 95 motor. And I know that the cams are going to be different, so I figured the fuel maps would probably have to be different as well, right? I mean I know it will probably run, but not well... (Or am I wrong?) I would do the wiring thing, but I am pretty sure I am only getting the bare engine, so I wont have the access to that, unless I buy it all separately.
-Artem
Artem Lepilov
Class of 2008
Artem
M42 wiring
« Reply #6 on: March 22, 2008, 03:06:07 AM »
Hello, I would like to bump this as I really need help.
I got the motor, its in very good shape, I want to put all my E30 accs on it, and run it, however I dont want it to run like crap when i put it in the car. I am pretty sure the cams are of a different design for the E36 318is, especially the later one - as I have the 95 motor, that is why I would like to know if anyone can tell me, if I put the stock E30 wiring harness and the E30 DME and sensors, what will happen to the way the car runs, I would like to have the similar fuel economy and the power of an E36, on a stock E30 DME, and for that I would probably just need a fuel map, right?
I am new to this mapping thing and I would really like some help please!!
Thank you!! :)
Artem Lepilov
Class of 2008
