I pulled the pan and sound some metal pieces and LOTS of sludge around the pickup. This could explain alot of things.. I noticed aswell that the there was alot of corrosion with the gasket between the lower timing case cover and the block. I have everything apart now so I just have to deal with parts.
So this is what I was thinking:
(Cars PD 06/93)
Lower Timing case to block/head.
- Steel Gasket 11141734422 12.25
- Profile Gasket 11141247849 6.00
Head:
- Head Gasket 11121721546 41.75
- Head Bolt Set - 13.50
- Head Bolt Washers - (10) 7.50
Lower Timing Case:
- Profile Gasket - 11141247837 4.25
- Gasket Set - 11141721802 10.75
- Shaft seal - 11141439570 13.75
Upper Timing Case:
- GASKET SET - 11141721919 9.25
OIL PAN:
- Gasket 11131739592 11.00
CRANK PULLEY:
- HEX BOLT - 11211721100 7.50
- FLAT WASHER - 11231709977 7.75
TIMING SYSTEM:
- GUIDE RAIL - 11311247470 53.75
- LOWER GUIDE - 11311721419 43.50
- CHAIN TENSIONER - 11311727342 102.50
- TIMING CHAIN - 11311247160 58.00
OIL FILTER HOUSING:
- O-RING - 11421709513 5.25
- GASKET - 11421709800 1.25
WATER PUMP:
- O-RING - 11511714519 8.59
INTAKE/EXHAUST MANIFOLDS:
- Intake manifold gasket - 11-61-1-734-684 6.50
- Exhaust manifold gasket - 11-62-1-728-983 12.50(2)
Roughly $450 bucks for above mentioned parts. Prices were from Pelicanparts.. I hate this car.
Also does anyone have a few pictures of what a good condition crank sprocket looks like? I think mines fine.
Otherwise i'll have to get:
- CRANK SPROCKET - 09/1993 11211247338 51.00pp
