Author Topic: Transmission conversion question  (Read 2279 times)
sijef
« on: March 10, 2008, 02:39:38 PM »
Hi all!
I need to know if the 5-speed tranny out of an early e36 325 is the same as that used in the e36 318is (m42 eng).
Does anybody know for sure?
j
« Reply #1 on: March 10, 2008, 02:43:55 PM »
i am not 100% sure but i think NO.. there is a m50 engine, am i right??
nicknikolovski
« Reply #2 on: March 11, 2008, 02:46:02 AM »
I looked in the bentley manual. It lists the following:
1992-1995 M42 318i/is/iC - Getrag S5D 200G/S5D 250G
(S5D 200G was discontinued 9/92 - also 200G & 250G are interchangable)
1996-1998 M42 318i/is/iC - Getrag S5D 250G
1992-1995 M50 325i/is/iC - Getrag S5D 250G
So basically the 318is uses the same g/box as the 325 after 9/92 however you can use a 200G in a 325 and vice versa.
Hope this helps, Nick
