Author Topic: Can someone please explain any differences between the IC & IS suspension components?  (Read 2388 times)
Cobra Jet
I've tried searching and there are not any real definitive threads on multiple BMW sites/forums about the actual (or factual) differences between the E30 318ic and 318is suspension components...
From what I have deduced so far is that the following components are exactly the same (including part #'s) and interchangeable between the IC & IS:
front brake rotors
front brake calipers (and pads)
front brake hoses
front wheel hub assemblies
front spindle nuts
front tie rod assemblies (both inner/outer)
front strut mounts
front bump stops
front control arms
front control arm ball joints
front sway bar end links
front "lollipops"
rear control arms
rear hubs
rear axle nut
rear wheel bearings
rear brake rotors
rear brake calipers (and pads)
rear brake hoses
rear sway bar end links
rear shock mounts
steering rack
What I cannot seem to get a real confirmation on, as far as compatibility, are the following parts:
front springs
rear springs
front strut inserts
rear shocks
What are the major differences of those parts (springs/struts/shocks) between the IC & IS??
Does anyone know the actual factory spring rates & heights for an IC vs IS?
Does anyone know if the standard 318is struts & shocks will work for a 318ic?
What is the diameter of the front strut housing on a 91 318, is it 51mm for a 91 318ic and is this the same for a 318is?
Can a set of E30 M3 springs be used on a 318ic?
I'm trying to price out front struts & rear shocks for my 91 318ic and some sites don't list any "ic specific" parts, while others do...  the same goes for the spring sets....
Help!  :confused:
« Last Edit: March 05, 2009, 09:53:19 AM by Cobra Jet »
- Phil
1994 Cobra coupe #0013
2011 Genesis Coupe
2011 Tucson GLS
