Author Topic: Bad ground  (Read 2379 times)
rfritz
Bad ground
« on: October 02, 2006, 12:59:38 PM »
I found a bad ground wire that connects the chassis to the suspension on the passenger side of the engine bay. The car starts fine now and before it would act like it had a bad starter. It also runs great now. The ground wire was opened up and I could see strands of wire. It was arcing and causing some electrical nightmare. Now everything is A-OK. It also solved my irradic idle problem Whooohooo!!!:D
