So, my power steering rack and/or pump has been groaning at startup (especially when it's cold out) for a while now, and seems to be getting worse and worse.
I replaced the reservoir, filter, and lines earlier this year... put in ATF with a near 50/50 mix of that an Lucas Power Steering Stop Leak.
I got that suggestion that it was good to run this mixture from the folks on the E30 M3 list. Said it's good for cars with older power steering systems. Mine isn't low, and I'm pretty sure there's no air left in it.
So, does this mean my rack is dying on me, or is there anything else I should be looking at??? The steering seems fine and noise goes away after a few minutes of driving and it doesn't leak anything.
Any ideas??? :confused:
