DISCUSSION => Engine + Driveline => Topic started by: Sean_318is on September 21, 2009, 09:40:47 AM
Hi guys, I've found water leaking onto my exhaust from the rear of the engine...
Any common things there? Thanks
from the rear of the engine?? nothing common there... check the coolant drain bolt in the block that is under the exhaust header right near the transmission bellhousing.
