PAPER OR PLASTIC => For Sale => Topic started by: sic///M on August 27, 2009, 07:08:18 PM
Everything available from DMEs to pistons and accessories. let me know what you need and make an offer
2 cylinder heads are available for $325 each. straight and in drop in shape with camshafts and sprockets attached
set of 6 or 8 pistons for the m20 guys $100 for all 8 or $50 for 4, thats including con-rods
prices are in USD
Located in Toronto, ON
good working icv? Also may be interested in ecu? Or do you just have the blocks.
Extra front and rear timing cases needed. Also a set of upper and lower oilpans... How much would you like for them if they are still available?
icv and ecu are available, timing cases and oilpans as well, Birdman16 if you'd like to, send me an offer and specify what you need, ICV and ECU i can do for $50 + shipping
hi ill take the 2 oil pans and front timing cover, and oil pump
how are the guides and chain rails?
Do you have a serviceable AFM for the M42? richwrench@gmail.com
Thanks, Rich
how much for a 175 DME and one coil pack to 96701?
I need a dipstick; pretty much the tube and measuring wand and any brackets hlolding it to the block.
Crank position sensor to 94903?
full intake manifold and valve cover to 91901?
nvm, and good luck
Hey do u have the valve cover bolts? if so how much shipped to 33534
Is that a m42 head. I need one and the side chain guides and crank sproket. Also the waterpump if its ina real good shape.
Thanks,
Dickie
do you have a block, crank and a good oil pump?
I have not received a PM nor a reply to my message; are the parts still available?
God I love it when people post F/S threads and then bail on them.
lol yea i here tht
I need rods and pistons... do you still have them?
wow, sorry guys, completely forgot having posted this, i have everything mention above, send me some pm's if still interested
thread revived, e-mail notifications turned on!!
i need a good crank sprocket/gear please email me a pic. I had the dealer order me one but if i can save a few bucks i will. my email is createdfromchaos @ gmail (dot) com
