DISCUSSION => Engine + Driveline => Topic started by: t.vederhus on July 06, 2009, 10:06:05 AM
hi
i have an m42 and thinking about doing a m20 flywheel swap.
i have read that i should use a 325 e30 flywheel.
but i have a e34 525i m20 flywheel. and from the partnumbers in realoem they dont have the same number.????
could i use the 525 flywheel as good as using a 325 flywheel?
yes, it's the same flywheel if they're both single mass, try to measure the weight!
