DISCUSSION => Engine + Driveline => Topic started by: JoeDellio on July 01, 2009, 03:52:48 PM
I got sent the wrong one, but I threw it in just to test things. I cant smell any fuel or anything, but since its suppose to have a 3.0 bar FPR am I inviting trouble?
Stupid question?
it will work just fine once the ecu adapts
cool, thanks. I was thinking it would just fire the injectors normal, but with a higher pressure they would dump more fuel.
if you disconnect the O2 sensor it will do so
What do u mean? If I disconnect the O2 it will adjust to it? Im not sure what you meant. Can you please clarify that for me?
the O2 sensor will tell the ECU to rich/lean the mixture. so if you disconnect the O2 sensor, the ECU won't be able to adapt to it and you will send fuel into your exaust...
ah, ok, I didnt know that he meant that.
I should maybe try looking into O2 sensor electrically.
What ways could I test the sensor and the harness themselves? My car is running pig rich as if it was dead or unplugged.
