DISCUSSION => Suspension => Topic started by: carlos318is on March 02, 2009, 06:14:01 AM
Title: E30 318is front shocks
Post by: carlos318is on March 02, 2009, 06:14:01 AM
Can anyone tell me if the shock inserts from a E30 325 will fit a 318is as on the OEM they are the same part number. But I would of thought they would be a harder ride:confused:
Post by: carlos318is on March 03, 2009, 03:39:05 AM
Does anyone know the ansure to this:confused:
Post by: Bl0mgren on March 03, 2009, 07:20:03 AM
318is have 51mm struts just like 325, so the shock inserts should fit fine.
Post by: carlos318is on March 03, 2009, 11:36:04 AM
Thanks mate just what I needed to know
Post by: RED IS 91 on March 03, 2009, 06:06:36 PM
Check out realoem.com to make sure . You should be able to compare the two struts .
