DISCUSSION => Engine + Driveline => Topic started by: rhogg on February 07, 2009, 04:22:09 PM
Title: Where does the FI vacum hose coneect
Post by: rhogg on February 07, 2009, 04:22:09 PM
I have replaced my starter and have everything back together after removing the intake manifold,  except part #11 on this real oem diagram:
http://www.realoem.com/bmw/showparts.do?model=AJ93&mospid=47318&btnr=13_0308&hg=13&fg=15.
Does it plug into the bottom of the throttle body?
Thanks
Post by: ghoulama on February 07, 2009, 05:21:48 PM
yes. there's a nipple facing down on the bottom of the throttle body under the TPS
Post by: rhogg on February 07, 2009, 05:57:34 PM
Thanks I took it apart again and found it.  For future reference disconnect the hose from the fuel injection pressure regulator and reinstall the throttle body with the hose attached.  It is much easier to connect to the pressure regulator than the downward facing throttle body nipple
