DISCUSSION => Engine + Driveline => Topic started by: scmooncake on January 30, 2009, 09:49:45 AM
Dear brother,
My car is 95 E36 M42 318IS AT. My engine can`t run above ~4500rpm...in either P,N and D shift. Is it had any prossible cases? I had already check the fault code (only 72 speed sensor problem). Many thanks for your kindly help!
What happens to it above?
Does it cut like it's hitting redline / fuel cutoff?
its prob a 325 gauge. they act like there redlineing at 4500, but there really at 6500...when put on a m42
your tach is probly just off a bit.
you need either a crankshaft sensor or theres probably an eninge speed sensor for the computer. mostlikly mounted on or around the transmision bell housing.
You can find one at Pelican Parts for $50.00.
It cut like it's hitting redline / fuel cutoff, anyway thanks to all of your kindly advise. i will check those possible cases !
I have had this issue with my car.
Replacing the Crankshaft position sensor and reseating the ECU connector solved it.
Dear roundel318
Thanks for your helpful info!!
Is it had any fault code?
If you need a replacement sensor, shoot me a PM. I just stripped a running motor.
That was part of the pain, I got no fault codes from it.
i think qiuene30 may be depressed....
sad sad story
I had a problem like that on my M3. Somebody had swapped a 6-cylinder engine cluster into the car, so the rpms read 2/3 of the actual value.
