DISCUSSION => Engine + Driveline => Topic started by: Ivan Petrov on January 30, 2009, 06:07:33 AM
Title: HELP! E36 M42 Intake Manifold Problems
Post by: Ivan Petrov on January 30, 2009, 06:07:33 AM
I need a graphycs showing how does the E36 M42 intake manifold works. There is a valve in the manifold and changes it`s position using vacuum, but I can`t find out graphycs how to get this thing to work properly. I mean, I don`t know how to connect it to vacuum, where from to get the vacuum and so on :confused:
Post by: Ivan Petrov on January 30, 2009, 04:06:28 PM
Anyone?:(
Post by: nicknikolovski on January 30, 2009, 09:12:57 PM
Use realoem.com and choose your vehicle. Then click on engine and intake manifold or vacuum control and click the picture depending on your year.
Post by: Ivan Petrov on February 01, 2009, 08:10:42 AM
I have already done this but I still can`t understand how to get it work
Post by: nicknikolovski on February 02, 2009, 03:18:38 AM
Post a picture of which valve you are taking about? There are few valves in and around the manifold. There is the PCV valve (after 9/93 build date), there is a one-way valve for the vacuum reservoir, there is a electric change-over valve for the vacuum system and there is vacuum box in the intake manifold and there is the idle control valve. You need to be specific.
Post by: Ivan Petrov on February 07, 2009, 04:08:28 PM
(http://static.bmwfans.info/images/epc/ODM1X3A=.png)
Number 1 is the cover of the valve
Post by: nicknikolovski on February 07, 2009, 07:00:33 PM
So is the valve no.6?
If yes - it connects to the electric change-over valve. Have a look for the black-coloured cylinder looking vacuum reservoir. It is located in a rubber mount on the drivers side close to the ABS pump. The change-over valve is above it on a small bracket. On realoem look up your car then look at the vacuum control section. You will see valve no.6 and how it is connected.
Post by: Ivan Petrov on February 09, 2009, 05:49:33 PM
Quote from: nicknikolovski;66085
As I thought... The black cylinder box is horizontal? under the intake manifold. Thanks :) If I have any other questions I`ll ask you, glad to know you can help me :cool:
