DISCUSSION => Engine + Driveline => Topic started by: nomad on January 04, 2009, 01:08:57 PM
I figured I should have replaced it when I had the head off but Nooooo I had to get in a rush and not wait for the order.
I think I'll steam clean the front of the engine before I do this, and i might as well do it along with the E36 steering rack I just got...
Anyone know of any "gotchas" in this gasket replacement? Hope there are no stripped bolts!
i would also like to know some tips as i plan to do this gasket replacement in a fe days, mine leaks like a faucet on startup
I replaced mine, it was pretty straight forward. I had to remove the alternator in order to get access to all the bolts. But everything went smoothly, I just followed the instructions in the factory repair manual. Of course now that I fixed that leak, I've got another leak from somewhere else too. Figures :mad:
Just replaced mine a few days ago... really straightforward as mentioned above. Just remove the airbox and alternator and you have easy access to it.
I guess it gives me the excuse I needed to get the dang car up on the stands again...
You replaced the o-ring too, right?
No need to put it up on stands, and yes, I replaced the O-Ring as well.
I also replaced the o-ring as well. No stands here either.
I'll put her back up and out of comission for a bit as i want to do E36 steering rack, e36 shift lever with rebuild and maybe a few other clean ups
o ring????????? are you guys talking about the filter top caps large o ring?
glad to hear it is pretty easy. i take it this is a common leak?
No, there is an o-ring AND a gasket for the filter housing body.
(http://lh4.ggpht.com/_GVjhH8d20fE/R6Eil4WrNVI/AAAAAAAADIM/FhmhXMfA4qo/s800/040805%20Oil%20Filter%20Mount%202.jpg)
IIRC, that upper round hole.
