DISCUSSION => Swaps, Turbos, Buildups => Topic started by: DutchM42 on December 08, 2008, 01:44:41 PM
Title: Info needed for buildup M42/M44
Post by: DutchM42 on December 08, 2008, 01:44:41 PM
My engine (M42B18) is in need of some new gaskets etc. so I was planning on doing a complete engine-job.
I have the option to buy a pair of rallycams (Catcams) which are at the max to suit hydraulic lifters. Before fitting I would like some headwork to be done.
The mechanic who works on my car has a lot of racingstuff in store. He has a M44 1.9 (fully balanced, lightweight pistons) with a prepped M42 head (with some wild cams) on top with Jenvey ITB's and Alpha-N. It is rated at 200 hp so that is more or less my goal.
I was wondering if I should stick with the M42 block or swap it for the M44 or go with a bigger displacement. And if so, how can I achieve that + does it have a negative effect on running high rev's being a stroker ?
Post by: marko on December 11, 2008, 08:21:13 AM
check these guys out... very reputable - & lots of good info on their M44/M42 engine section.
http://www.metricmechanic.com/
http://www.metricmechanic.com/pdfs/metric-mechanic-m42-and-m44-engine-booklet.pdf
Post by: roundel318 on December 11, 2008, 06:42:05 PM
Quote from: marko;62636
+1
Their engine's are nice, and well built to live another 200,000 miles!
Post by: crazzy_hippo on December 12, 2008, 06:16:19 AM
If you are going for 200HP, recommend you stroke + bore up the engine. Use the M47 diesel crankshaft and 86mm pistons.
Post by: sikdogg on December 12, 2008, 11:22:23 AM
Quote from: roundel318;62658
+1
for ~$10k, it better...
Post by: marko on December 13, 2008, 08:12:45 AM
it can be much less if you are willing to seek a machine shop of your own & just by internals from them... I almost went that route - but ultimatelly figured F-it - & let them put the whole thing together.
Quote from: sikdogg;62692
Post by: roundel318 on December 13, 2008, 10:01:40 AM
Quote from: marko;62740
They have done it more than once, suggesting it could go smoother :)
Post by: DutchM42 on December 15, 2008, 12:33:37 PM
Thanks guys. Already knew the MM-boys. Just a pity they are on the other end of the ocean :D
I came across a German site with strokerkits for the 316i,318i and 318is. The 318is was 2042 cc so that must be the M47 crank with pistons swap. They didn't mention anything of headwork being done but they rate their engine at 174 hp. Is that realistic ? Upping the displacement with 250 cc and gaining an extra 34 horses (might be incl. adjusted chip)?
When I have a look at the 50 horsepower gain Dbilas claims with their setup of headwork, cams, ITB's and Alpha-N on the stock M42B18 how does that work with a bigger displacement ? What can I expect from stroking the engine and combining that with the full Dbilas-setup ? And does the stroked bottom-end still likes to be revved beyond 7k rpm's ?
A friend of mine has the M40B16 stroked to 1.8 with the M43B18 bottom-end. He has got the full Dbilas setup and went up from 92 hp stock to 155 hp.
Post by: marko on December 16, 2008, 06:23:31 AM
not really sure what the Dbilas set up is - but I sure would like to see the link with the german stroker motors.
if it makes you feel better - MM also suggests their stroker output to about 175hp - so I'm sure there is some truth to it - considering it is a similar concept.
Quote from: DutchM42;62835
Post by: Lund8200 on December 16, 2008, 02:07:36 PM
You bet it does.... Belive me, my stroked M42 revs very well af 2068 ccm with the M47 crankshaft. Been driving it for more than a year now.
Try having a look at my postings in here.
Would also like to see a link to these German strokers?
Post by: DutchM42 on December 16, 2008, 02:28:31 PM
I can't remember the website, but I think it's from G-power because the specifications look exactly the same:
G-POWER strokerkit G3 2.1
Basis 318is Motorblock Modifikation to 2042ccm,
174PS (128kW), torque 220Nm
1x G-POWER balanced crankshaft
4x G-POWER lightweight pistons
4x G-POWER balanced conrods
Complete gasketset
Wasserpumpe
ECU-optimizing
incl. 24 months garantee
Post by: DutchM42 on December 16, 2008, 02:29:59 PM
Another one, former Alpina enginebuilder:
http://www.noellemotors.de/2_1l-4_valve_engine_basis_BMW_M42_M44.232+M5b36deed99c.0.html
Post by: DutchM42 on December 16, 2008, 02:36:55 PM
Thanks for your reply Lund. What's your guess, if 50 horsepower is gained like Dbilas claims with stock displacement, is 210-220 hp with 2042 cc a realistic figure ?
M42B18 DbilasStep IV : Upgrade to 140kW / 190HP includes:
• A throttle body injector system 1453,--
• A set of sport camshafts 587,--
• Cylinderhead and Valve modification 845,--
• Complete software update 355,--
• a/N 2000 control unit to replace the 889,--
air flow meter
Post by: Lund8200 on December 16, 2008, 03:03:29 PM
I am pretty sure it is not easy to get past 200 horsepower, but a lot would depend on what kind of ECU you choose, and if you ever get such power I doubt it would be a everyday driving car like mine.
Ceotto from this forum is building a very similar engine, but with special made cams, solid lifters and ITB΄s. But I think he still need a lot of work before starting it.
Post by: swiss318is on December 16, 2008, 03:42:22 PM
hey guys..interesting thread! i am currently in this engine-building thing too.. and we dont have any idea how much hp we will have at the end.. but +/- 7500-8000rpm and 170-190hp with:
stock block (bored, honed etc) with stock displacement
balanced crank
balanced and lightened flywheel
custom mahle pistons
custom h-rods (bmw-motorsport?)
fully ported and machined head
polished and machined valves
cutted valveguides
custom exhaust manifold
stock intake
wild cams
solid lifters
new programmed ecu
and the cr about +11:1 we will see...
and for the racing engine the same.. except the m47 crank and dbilas itb's... guess around +230hp but i dont think you can drive that on the street...
Post by: Tonppa on December 18, 2008, 05:23:29 AM
I had 176hp@6720/ 203Nm@5800 with regrind cams, slightly ported head (only intake side), 10,8cr (wiseco pistons) and ebay chip.
Ebay chip and stock injectors caused "some" pinging and corroded head. :/
In my setup stock AFM restricts badly top end power.
Now putting m40b18 rods and pistons in for a turbo :)
(http://i285.photobucket.com/albums/ll55/Tonppa11/m42/dyno.jpg)
Post by: swiss318is on December 18, 2008, 11:43:08 AM
Quote from: Tonppa;63096
UUIIIIIII!!! in this case i am gonna hit the 200hp mark with my engine? :D
Post by: swiss318is on December 18, 2008, 11:53:37 AM
everything else stock? ... hmm... i have a big smile in my face right now..
Post by: DutchM42 on December 18, 2008, 12:18:42 PM
LOL :)
Thanks for the replies so far. This winter I'll decide which components are the best for my needs.
Post by: Tonppa on December 18, 2008, 02:26:59 PM
Quote from: swiss318is;63129
Sorry, forgot PUG Mi16 intake valves. Those are plug n play.
Rest is stock.
Would have been few hp more by adjusting cams, but loose some from bottom end.
http://www.prospeedracing.net/
This thing has ~230hp with about same mods as mine has +stand alone & ITBs.
Post by: nuvolarossa on December 18, 2008, 03:59:04 PM
aren't Mi16 34,5mm valves?
Post by: swiss318is on December 18, 2008, 06:33:22 PM
Quote from: Tonppa;63144
Rest is stock.
hm... why do you need peugeot valves? if they are plug n play.. do they have the same diameter? doesnt make a lot of sense... and if not you need some new valveseats...bigger job on your head!
what is so special about those valves?
do you guys think i am gonna have about 200hp with my configuration?.. would be amazing.. and about the stock ecu with chip.. i can easely change to a fully programmable ecu...
in this case... it would be no problem to make a s42 replica .. ~280hp!? it seems ways too easy to me..
