FAQ / REFERENCE => M42 Reference => Topic started by: nelsone30 on November 26, 2008, 12:40:38 PM
Did anyone of the forumers have this experiences with when engine cold down start cranking with 1500 RPM problem
When you cold start the engine it idles up to 1500rpm?
How does it idle when warm?
Does the cold start behavior change when you disconnect the ICV and start? (Idle Control Valve, top/rear of engine between intake manifold and valve cover next to firewall, has two hoses, one running from end of valve cover to ICV then from ICV to MEDUSA under intake manifold)
mine does it, im about to work on the ICV...i'll let you know how it goes.
Anyway i just scared of the hydraulic lifter which every morning i startup the car with the noisy sound so i will check it out with the hose....etc. But my car the ICV i have connected so it doesnt really matter with the sensor and wiring. Thanks for sharing.
when comes to warm the car idle is cold, what i mean when the car cold then start cranking the car the engine lifter sound very ralph. Is it normal for m42?
spammer:@
