DISCUSSION => Engine management => Topic started by: 325eire on November 24, 2008, 05:38:40 PM
Title: no spark
Post by: 325eire on November 24, 2008, 05:38:40 PM
howdy all  im  resently new here cos i just bought a e reg 325 and its fooked already hope someone can help me  it drives for about ten minutes from  cold and then cuts out once its warm no spark   my head is minced  any ideas i think the  igniter is in the dme   crank sensor ? thanks
Title: no spark
Post by: JP 91iS on December 17, 2008, 03:01:22 PM
Quote from: hongri1998;63015
A v port ball valve (http://www.valvesupplier.net/petro-valve.htm) has either a 'v' shaped ball or a 'v' shaped seat. This allows the orifice to be opened and closed in a more controlled manner with a closer to linear flow characteristic. When the valve is in the closed position and opening is commenced the small end of the 'v' is opened first allowing stable flow control during this stage. This type of design requires a generally more robust construction due to higher velocities of the fluids, which would quickly damage a standard ball valve (http://www.valvesupplier.net/petro-valve.htm).
now that is some weird spam
